Onza Pro 2009 Wheels?
OnzaPro
Hi Can somebody help me?
The rear hub on my onza is damaged and are worn and you could see the bearings.
Also the threads are damaged.
What should I do Replace the Rear hub and rebuild the rim or
buy a new wheel.
Does it matter what size hub I get.
Can somebody please help.
Thanks
Edited by OnzaPro
Hello.
I think I can help you.
If I were you I would buy a new wheel.
Go for a wheel such as the Echo TR 19" Disc wheel.
Sealed hub bearings.
Wider rim.
Stronger wheel.
Decent price.
You will need a 12t screw on sprocket too.
Whats your current frame?
No worries.
Please type in the default layout too :')
Makes it less weird to read.
  • Like 1
