brad1995 Posted May 10, 2012 Report Share Posted May 10, 2012 Right, every time i try to grind my rim i always get the same result, a rough but very dull rim. I have tried changing the angle and pressure that i am grinding at and also tried using brand new grinding disks but nothing seems to be working. I was just wondering if anyone could help me out on getting a nice medium grind if possible, im running an echo urban rim (rear) just in case anyone wants to know. Thanks, Brad. Quote Link to comment Share on other sites More sharing options...
Revolver Posted May 10, 2012 Report Share Posted May 10, 2012 Make sure you only grind in one direction. Don't wipe the grinder back and forwards, it undoes some of your work. Quote Link to comment Share on other sites More sharing options...
brad1995 Posted May 10, 2012 Author Report Share Posted May 10, 2012 Tried that as well :/ What type of grinding discs are you guys using ? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 10, 2012 Report Share Posted May 10, 2012 Metal cutting (stainless steel) disk. Please don't tell me you're using a flapper disk? Quote Link to comment Share on other sites More sharing options...
liam n Posted May 10, 2012 Report Share Posted May 10, 2012 Try using a Diamond cutting disc. You can get diamond tile cutting disc or stone cutting. stone cutting seems to be sharper, but it has notches in it (still works though) give one of these ago, you can pick them up for £1.75 to £5. and just a gentle skim makes a perfect harsh grind. if you don't want to buy one i'd say use a brand new metal cutting disc (not grinding disc) and make sure it's sharp. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 10, 2012 Report Share Posted May 10, 2012 Also turn off the grinder every 1/4 revolution of the wheel and get rid of any aluminium stuck in the grinding disk to ensure youre getting a sharp constant grind. Quote Link to comment Share on other sites More sharing options...
brad1995 Posted May 10, 2012 Author Report Share Posted May 10, 2012 I'm not using a flapper disk I think i will try using a metal cutting disk and clean it every 1/4 of the wheel and if that doesn't work i will try a diamond cutting disk. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted May 10, 2012 Report Share Posted May 10, 2012 I've had the same 6mm stone grinding disc for about 2 years, never cleaned it either and it still gives really nice sharp grinds that last me months. Really don't know how some people's grinds are that bad. Quote Link to comment Share on other sites More sharing options...
brad1995 Posted May 10, 2012 Author Report Share Posted May 10, 2012 I used to be decent at them but all of a sudden i'm rubbish ! Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 10, 2012 Report Share Posted May 10, 2012 Depends on what rim you have too... Quote Link to comment Share on other sites More sharing options...
onzatrip Posted May 11, 2012 Report Share Posted May 11, 2012 im running an echo urban rim (rear) just in case anyone wants to know. You are doing it wrong, I have same rim, used the same disc for 3years, Try using a 60 degree angle with pressing and sweeping motion, thats how i do it and have some of the best ground rims ever! Quote Link to comment Share on other sites More sharing options...
