Matt24. Posted May 9, 2012 Report Share Posted May 9, 2012 I would like to disconnect my hope hose run through steerer and reconnect however clearly the metal connectors will need to come off to get it through however as I have only ever experienced maggies, are the connectors re-usable with the hose or will i need a new hose or connectors or both, The hope bleed kit seems immensely expensive, has anyone bled these with the car/ motorbike method of topping up resevoir and pumping etc? Quote Link to comment Share on other sites More sharing options...
JD™ Posted May 9, 2012 Report Share Posted May 9, 2012 You can definitely re-use all the bits associated with the hosing. My bleed kit for my Hopes consists of a bit of plastic tubing to attached to the bleed nipple, then the process is exactly as you described - didn't know there was another way... Then again, I had to get Ali to do mine because I wasn't able to get a decent bleed on my discs. 1 Quote Link to comment Share on other sites More sharing options...
Matt24. Posted May 9, 2012 Author Report Share Posted May 9, 2012 Haha well, the kit on tartybikes is some crazy contraption looks like that connects to your tube to use air to bleed it? I am going to stick with a home made kit probably buy a new piece of hose and use original connectors....... Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 9, 2012 Report Share Posted May 9, 2012 That's a Magura bleed kit. Quote Link to comment Share on other sites More sharing options...
Matt24. Posted May 9, 2012 Author Report Share Posted May 9, 2012 My apologies I didn't see it on tarty bikes it was crc. To the question Mark, would you advise replacing hose or would it be ok to just undo connectors re-use and get some fluid from you guys to bleed. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 9, 2012 Report Share Posted May 9, 2012 You shooould be able to re-use them if you're careful. For the hose length it kinda depends really, I think a lot of the time you'll probably need a touch more hose than a standard front to get it to work properly. Quote Link to comment Share on other sites More sharing options...
brad1995 Posted May 15, 2012 Report Share Posted May 15, 2012 Quote Link to comment Share on other sites More sharing options...
