Hope Pro 2 Eveo Front Hub Probrem
Matt Vandart
ti is more likely stretching.
i would never run a ti skewer in trial bike they are more likely to snap than a steel one as the ti will stretch then snap
I've been using titanium bolt through skewers on my triton for years, yeah they might stretch slightly but wont snap.
Matt, have you checked that the skewer isn't bottoming out on the axle stubs? I've had it before if the dropouts are a little thin, the skewer caps can bottom on the axle stubs before properly clamping the dropout. I would also have a look to see if the kcnc skewer caps have a flat clamping surface, iirc the hope ones are counter bored in the middle to give clearance for the axle stubs to protrude the dropouts slightly.
