Rear Freewheel On A Mod?
Just an idea me and my other half have been kicking about. And having looked at the hub and realising that i could quite easily fit a rear freewheel.
What would you guy's say are the Pro's and Con's of doing this, also what freewheel would you recommend when doing this.
And would this eliminate the need for a bash plate/ring?
Main reason for asking is i really want to run a set of middleburn's and i know damn well i can't with a front freewheel.
Thanks Lucy
You'd still need a bashplate or ring and you'd have to run a bigger than normal sprocket up front. Your best bet is trying to get hold of a profile or chris king freehub. Otherwise you want a 16t freewheel at the back and a 22t up front I think.
Edited by isitafox
  • Like 2
with an 18t sprocket on the rear you'd need a 27 tooth sprocket up front to get the same ratio as 18 12 which would be hard to get for burns... you'd still need a bash ring, to protect the chain and sprocket...
other then for cosmetic reasons why are you so adamant you want to run middleburns? providing you maintain your cranks they all do the same job. Im a big guy and rode a set of basic onza muscle man cranks on a mod for 2 years when i rode. just make sure you check cranks bolts etc when you ride. Also has been said most rear freewheels are shite you would need to get a freehub if you want something you can trust.
Was just an idea as we have two pairs of middleburns available for use, and I've been trying to find any way of getting my mod built and finished. Have realised the flaws of rear freewheel now. But thanks for all your help anyway guys :)
Really, where did you get this great snippet of information? Last I checked freewheels are freewheels whether you choose to screw them to your crank or hub. There are a few reasons to put a freewheel on the cranks rather than the hub but increased reliability is not one of them.
Saying this however, I also do think freehubs are more reliable than freewheels but that is a seperate issue.
this may be me with my ilogical head on but would they not be threaded in different directions for use on cranks or rear hub therefor a specifically designed front freewheel would in theory losen itself on the rear or just freewheel and not engage? Its been a long time since ive used a freewheel and a long day it work is making my brain struggle to engage properly at the moment.
No. Threads are the same but the freewheel would be flipped over, hope that makes sense :P
  • Like 1
Im running middleburns trials pro 22T to 16T rear mounted Viz 72 freewheel.(24") which is working out a great ratio for general/natural trials but slightly too low for street i think, depends on your riding style.
I though the main reason for putting freewheels on the the front was for additional clearance if your bike had a Low BB. other than that, lossing a couple grams and not moving the chain when back pedaling I see no Difference in performance.
If your left foot forward... why dontcha get real crazy and flip the wheel/ freewheel and cranks round and run it on the back and non drive side! :w00t:
funk the norm!
on my rock man 108 sl, the lockring is fastened on clockwise, so on ffw will stay tight. if it were on the back, it will become loose. an acs claw lockring is threaded on left hand, so would come loose on the front, I know this cos I had one. they are advised for rear use only because of this
(null)
Edited by danchandler
