Clamps Causing Sticky Pistons.
dann2707
Bit of an odd one. But I have some Echo clamps that i've removed so much material from the faces so that they don't require the plastic / metal washers that clamp the maggy slaves.
I'm pretty certain they are causing the pistons to return slowly as if I remove the clamps the pistons push out and return super fast as they should.
Has anyone else had similar experience with clamps causing this problem?
