Embarrassing Question
JayCam
Surely it's just a case of slackening whatever is holding the chain in tension. Then sliding the chain of the rear smaller sprocket and then follow it by taking it off the front sprocket. That should give more than enough slack to slide the wheel out. There's no need to take the cranks off just to remove the back wheel.
This. Ive never owned a crank extractor and managed fine.
yeah but not always, my echo doesn't have enough, so even if you slacken it off completely the chain still wont come off the sprocket, it would if the chain had 1 more link, but obviously you cant just add one link.
therefore i have to take my crank off too. and i cant break the chain as im running a moped chain pretty much haha.
