TheLeroyHUK Posted May 1, 2012 Report Share Posted May 1, 2012 got a upgrade from the old comp frame i had....with the onza having its own shite tensioner system im new to snail cams....how on earth do they work? my ne frame does have two allen key bolts if thats any help.... videos would be much apreciated... cheers liam Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 1, 2012 Report Share Posted May 1, 2012 http://www.tartybikes.co.uk/media/guides/maintenance_snail_cam_setup/m5.html Quote Link to comment Share on other sites More sharing options...
TheLeroyHUK Posted May 1, 2012 Author Report Share Posted May 1, 2012 i watched this 10+ times with no luck....what are the bolts for?? do the actual snail cams connect onto them? the video explains how to us them but not how to fit them 1 Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted May 1, 2012 Report Share Posted May 1, 2012 The bolts screw into the frame and are what the external surface of the cams push against to stop them from slipping forwards. The bolts are critical to the function of the cams. When Ads is pushing on the cams and you hear the click, that's the next notch on the cam locating on the bolt in the frame. Edit: What they look like when run on the outside of the frame (note depending on your setup you may need to run them inside the frame): Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted May 1, 2012 Report Share Posted May 1, 2012 You have to put them on hub axle,that´s all.You might need to modify hub spacers though. Quote Link to comment Share on other sites More sharing options...
TheLeroyHUK Posted May 1, 2012 Author Report Share Posted May 1, 2012 (edited) i'd tell you what frame i have buts its a suprise to my friends.... its a mod 116mm spacing on my frme, doesnt look like the cams will fit on the outside.... if i go by the pic but put it on my hub, that looks most likey... and then simply push down on the cams untill the click..... i think i've got it cheers Edited May 1, 2012 by TheLeroyHUK Quote Link to comment Share on other sites More sharing options...
