Over Tightening Headset?
Skorp
Hey
i have personally never broken any forks, but last month a friend of mine broke his SL at the steerer crown.
I thought that it was purely because the Sl's beeing light..But i have thought abit about this.
The ride before, his headset was really loose. So i tighten it alot. Way more than needed, but the steering was still smooth.
Could this be the reason his forks broke? Could this be the reason to many fork failures?
I know.. Thats not what im asking for.
The headset he uses is a Echo SL. You can tighthen them ALOT before they get harder to steer. So i guess somthing like 5nm torque on the bolt is ok.
Then everything is tightly fitted. The stem, headcap, stackers, bearings and crowns are compressed allittle. My guess is you could easily torque the bolt to 15-20nm withouth notice any differance on the steering itself. Altough, the difference in linear force the headset bolt makes on the steerertube would be huge compared to 5nm, and would make it snap alot easier... thats my theory atleast.
Edited by Skorp
I'm offcourse not talking about pulling the steerertube out by tightening the headset too much..
I talk about the pullingforce the bolt makes on the steerertube. this force, will in my eyes give the steerertube more stress and a crack will occur much faster if the headset is tightned excessive..
Just think about whats the factors here, and not just think that a SL fork cracks anyways..
Edited by Skorp
Yeah, thats probably true.. but what about over time?
Its a quite big torque difference on a SL headset from "tight" until it doesent roll properly. If you just tighten the headset bolt as much as possible, and not just as much as needed, my guess is that the steerertube would have several 100kg's more tension than you need.
I dont care about his forks.. i care abouth the physics involved here, and i think that this might be something to consider when tightening your headset.
Because i'm a heavy rider. I weight 220lbs, and i have used Neon snap happy forks for some time now without problems. Hooks and up to front alot .. Altough, my friend who is somthing like 160lbs, he broke his neon fork in no time.. Why is this then? We ride on the same stuff, ride just as much? but he's alot smaller than me, and breaks more forks
The guy with the broken SL's boorowed a fork from me until he got a new one. I'm not going to buy new parts if something breaks just after i help somone with their bike.
Edited by Skorp
more aggressive technique, isnt as smooth maybe?
or... trials components aren't the highest quality in the world of cycling so the strength probably isn't all that consistent? Maybe he got a couple of " bad" forks with minor defects?
