Help A Brotha Out. Echo Sl Lockring
N.Wood
I'm calling on the forums expertise to help a brotha out.
Trying to get the lockring off an Echo SL but its proving to be troublesome.
Anyone know if its reverse or standard thread? Any trick to getting it off?
No I can't ring Tarty. Need this shit ASAP..
Much appreciated!
Standard thread.
They can be tight, as they will tighten up when you pedal.
- Bolt tool to FW (use an old square taper LH BB cup screwed into the FW)
- Clamp tool in vice
- Twat hole in lockring with old screwdriver/chisel and hammer
(Y)
  • Like 2
  • 2 weeks later...
