Choosin A New Frame
colly
firstly decide whether you are goin to be ridin natural or comp, a street frame won't be great for comp as these usually have smaller top tubes, check out the warrenty on the frame, make sure the bb height is over 12.5 '. check the tyre clearance, try to pushing the rear dropouts to see how stiff it is. and check out reviews on biketrials.com, if you buying a koxx make sure you can live without having a seat, hope this some help, please keep adding frames in and extra advice. thanks :thumbsup:
Long frames = UCI...
Short frames = BIU, street etc etc.
You don't need a long frame for UCI though.But it helps. You can ride street on a UCI frame. You can ride whatever you want with whatever frame you want :-
Resources:
The search function
  • 3 weeks later...
  • 1 month later...
Sub £200
Saracen Mad- £130-£140, removable bashplate, white or black, longish chainstays, long front end, average BB height. Rides Okish, V mounts
Monty Urban- £150, 25" rear wheel, can be bodged, comes in silver, red or black, 1035mm wheelbase 4 bolt mounts
Base TA26-Short Chainstays, 1040-1050 wheelbase? Silver, from geometry shuld ride nice and seems a bargain really. £179
Sub £300
Zoo Boa- £295, around 1040 wheelbase, short rear end, V mounts and seat, or 4 bolt and no seat.
BT Raven 4.0-£279, 382mm chainstays, 1090 wheelbase, come in white, silver or black, black seems hard to get though. 8" seat tube, +5mm rise bb, short headtube means low bars without some spacers. Ideal UCI bike for people on a smaller budget.
Sub £400
Koxx Levelboss-v short chainstays, 1040,1065 or 1100 wheelbase, Better suited to people who prefer "proper" trials, too long for bmxey street. Very strong, 4.9lbs, silver £395
Leeson-£400, lightish, steel, custom length, host of crazy features like 360 dropouts, strong, can be rewelded if it cracks, range of paint jobs.
Brisa B26D/B26- £350, long chainstays, shortish front end, coem in range of paintjobs, B26D anodized, V mounts, not the best geometry for trials
Echo Pure-£395, see Koxx, come in 1060 and 1080, U6 alu, 4.2lbs, silver
Ashton Justice-£414, short chainstays, 1035 wheelbase, 4 bolt mounts, silver, detachable seat, light, good for short people or people who want a nice riding frame but no length.
£400 +
Zoo Pitbull-£425,Coustellier copy frame, silver, 1060 or 1090 wheelbase, short chainstays, 4 bolt mounts
Curtis T1-£550, varying weights, varying lengths now, lots of colours, very strong, steel and can be rewelded, best suited for the full on street rider who breaks things often.
Pashley 26GHZ-£450, lightish, not out yet, double seat tube, steel and can be rewelded, 1010 wheelbase
Theres a very short guide to the best frames out there, post if I've missed any.
Now updated slightly
  Dan-slicktrixtrials.tk said:
Sub £200
Sub £300
Base TA26-Short Chainstays, 1040-1050 wheelbase? Silver, from geometry shuld ride nice and seems a bargain really. £299
Zoo (insert animal name here)- £295, around 1040 wheelbase, short rear end, V mounts and seat, or 4 bolt and no seat.
Sub £400
Ashton Justice-£395, short chainstays, 1010 wheelbase, 4 bolt mounts, silver, detachable seat, light, good for short people or people who want a nice riding frame but no length.
£400 +
Zoo Pitbull-£425,Coustellier copy frame, silver, 1040 wheelbase, short chainstays, 4 bolt mounts
nice one dan. this is the first post in this thread that is particularly helpful.
(Y) good job
john
  • 4 weeks later...
so what's the advantage of something with lots ofg standover height, say a mad (10"?) or a pashley which has more, I notice lots of frames are now being produced with really low standover. How low can this go? 3"??? 2""???
A frame to be added to the above list in the sub £300 bit, is the new BT raven, very short 382mm chainstays (shorter than a koxx) very long 1090mm wheelbase, it is more designed towards the "proper" uci style of riding, it has a 5mm rise BB, also availiable in black, white or silver and it rides amazing, better imo than any other frame, be it more or less money, except maybe an echo 1080m pure, but I haven't ridden one so can't compare.
No, because the seat-stays and top-tube would form a reflex angle which would put a lot of stress on the seat-stay/tube/top-tube join. Equally, if it gets to 3 inches or less, where are the tubes going to fit together? More stand-over height means more room to move your body when you're pre-loading for sidehops and so on. Equally, it tends to mean less tubing, which generally means less weight. Also, when you're doing natural you can move your body over the bike more easily to balance and so on. (Koxx frames have 8" seat-tubes, I think)
Onza T-Raptor is in the sub £200 band, might be worth a look.
Try and give the bike you're considering a try-before-you-buy. It's worth it, especially seeing as the more specialist bikes tend to get pretty extreme across the geometry spectrum, where you get fairly short bikes like Leeson's, going to super long bikes like the Koxx Levelboss 1100. Don't forget not to get too wrapped up in the facts and figures - 1060, for example, may sound like a lot, but when you ride it it can feel super nice. Don't just think "It's a big number, I'll hate it." Just give stuff a try and be open minded.
  Quote
£414 price of ashtonbikes.com And 1035 wheel base using a fatty fork mines about 1040 with a ashton fork. nice to ride, good for all round stuff, just im not sure how strong it is. any body no please post thanks :(
  • 1 month later...
  Quote
Sub £300
The Base, at £169, is actually 57% of that price atm! Less than 1/2 the price of an Echo. You can't beat that value for money.....surely :(
  • 3 weeks later...
  • 3 weeks later...
the natural frames usually have a slacker head angle thus meaning it is longer. and will be alot easier to tap with a slack head angle (Y) I think (Y)
