F.N.G Posted April 23, 2012 Report Share Posted April 23, 2012 Hi guys I have heard a lot of rumors 05 maguras cracking, and I just brought one, and I know a lot of people grind or cut of the area where it is likely to crack. Does anyone have any pictures of where to grind off? and where it is likely to crack? Thanks a lot people, I do not want this brake to go to waste Quote Link to comment Share on other sites More sharing options...
krazykid009 Posted April 23, 2012 Report Share Posted April 23, 2012 Yeh, I've killed four.... Should've gotten an older one! Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 23, 2012 Report Share Posted April 23, 2012 They're awful. Properly nice when they're in one piece, but far too weak I think. I was lucky enough to get hold of an old Echo SL lever body. Running my old 05's internals and lever and works a charm. No chance of it snapping either Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 23, 2012 Report Share Posted April 23, 2012 They are usually fine if you grind off the edge. Much comfier than the pre-04 ones. Anyways, you see the + and - sign next to the tpa? That 90 degree corner is where the crack starts. I will try and find a pic of where to grind off. Quote Link to comment Share on other sites More sharing options...
krazykid009 Posted April 23, 2012 Report Share Posted April 23, 2012 Should also add, all four of mine had the corners cut off.... Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 23, 2012 Report Share Posted April 23, 2012 Mine too. All cut and filed smooth. To no avail. 1 Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 23, 2012 Report Share Posted April 23, 2012 Fair enough. I've snapped them in half but only when they've not been modified. Also cracked the lever bolt area from work hardening I guess. Anyways, might be worth looking at your lever angle to see if you're putting alot of stress downwards on the lever blade if its an issue. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 23, 2012 Report Share Posted April 23, 2012 I used to leave my lever bodies a tad loose. Not so loose as they would easily rotate, but so that when really hit hard they would slip around the bar. Prolonged them a while longer. Quote Link to comment Share on other sites More sharing options...
Blake Posted April 23, 2012 Report Share Posted April 23, 2012 Yeah I can move my levers by hand, means if you fall off they don't snap Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted April 23, 2012 Report Share Posted April 23, 2012 (edited) If you needed a visual representation then this could be an alternative to 'N.Wood' 's post Edited April 23, 2012 by streetrials24 1 Quote Link to comment Share on other sites More sharing options...
isitafox Posted April 23, 2012 Report Share Posted April 23, 2012 I've got a topic somewhere from when I did mine, only cut the bottom off and it was fine! Here you go boy Quote Link to comment Share on other sites More sharing options...
Cap Posted April 23, 2012 Report Share Posted April 23, 2012 I've got a topic somewhere from when I did mine, only cut the bottom off and it was fine! Here you go boy http://www.trials-fo...age__hl__+crack I only cut the bottom off and mine have been fine too. Quote Link to comment Share on other sites More sharing options...
F.N.G Posted April 24, 2012 Author Report Share Posted April 24, 2012 I've got a topic somewhere from when I did mine, only cut the bottom off and it was fine! Here you go boy http://www.trials-fo...age__hl__+crack Thanks Dave, I noticed that part was already ground of when I got the brake, I also noticed there was two cracks that he did not tell me about, so they went off quickly. I think it should have less chances braking now as I have done this. I'm really exited to ride it tonight here it is http://instagr.am/p/JxveXIoG-0/ Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 24, 2012 Report Share Posted April 24, 2012 Hey Tom what happened to dual disc on my lovely old Zhi frame? Quote Link to comment Share on other sites More sharing options...
F.N.G Posted April 24, 2012 Author Report Share Posted April 24, 2012 (edited) Hey Tom what happened to dual disc on my lovely old Zhi frame? haha, well I just wanted to see what maggie is like. and it is paying off now You wont believe how much more bite it has Edited April 24, 2012 by F.N.G Quote Link to comment Share on other sites More sharing options...
