Greetings Posted April 21, 2012 Report Share Posted April 21, 2012 Ok I've often come across this problem but don't know how to deal with it properly. When truing the wheel vertically the left and right sidewall often run independently. You'll get one side perfectly round only to find that the other one has a lot of bumps even though the spoke tension is fairly even. This is especially problematic with very light rims or ones with no stiffness whatsoever - usually front ones. I find that trying to get the other sidewall right often distorts the one you've just finished doing. Is there a method to get both sidewalls even other than just endlessly flipping the wheel over? I'm not talking about rims with a big spoke offset here, just the normal stuff. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted April 21, 2012 Report Share Posted April 21, 2012 take it apart, turn every nipple the same turns all the way round and it should be fine? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted April 21, 2012 Report Share Posted April 21, 2012 Its almost impossible to equaly tension a trials rim, probably the closest I have come to equal tension is with rear TR rims Quote Link to comment Share on other sites More sharing options...
Maxx Posted April 21, 2012 Report Share Posted April 21, 2012 Because trial rims are poor made. The same thing with lateral errors : you can perfectly laterally true a side, the other side will be not as true as the precedent. Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 21, 2012 Author Report Share Posted April 21, 2012 Because trial rims are poor made. The same thing with lateral errors : you can perfectly laterally true a side, the other side will be not as true as the precedent. Yeah that happens frequently too. Quote Link to comment Share on other sites More sharing options...
Ali C Posted April 21, 2012 Report Share Posted April 21, 2012 tough luck I'm afraid, get one side straight then don't look at the other, I find that normally works Quote Link to comment Share on other sites More sharing options...
