weebryan Posted April 14, 2012 Report Share Posted April 14, 2012 (edited) Is there a torque or a sound like a guitar string that I can tension spokes up to. I have a guitar app I can use The wheels are echo tr 24 and seem very loose and every time I put pressure through drive I can hear them move/ping and same on front http://www.bikexprt.com/bicycle/tension.htm Edited April 14, 2012 by weebryan Quote Link to comment Share on other sites More sharing options...
eskimo Posted April 14, 2012 Report Share Posted April 14, 2012 I think Sheldon Brown covered this. Apologies if not, i would of read that somewhere else. Here is a quick link. Quote Link to comment Share on other sites More sharing options...
JD™ Posted April 14, 2012 Report Share Posted April 14, 2012 I think Sheldon Brown covered this. Apologies if not, i would of read that somewhere else. Here is a quick link. Just because I was interested, I plucked this bit out of the link: The second way of judging spoke tension is by plucking the spokes where they cross and judging the musical pitch they make. If your shop doesn't have a piano, and you don't have perfect pitch, you can compare it with a known good wheel that uses the same length of spokes. This will get you into the ballpark. Before I started using a spoke tensiometer, I used to keep a cassette in my toolbox on which I had recorded my piano playing an F#, a good average reference tone for stainless spokes of usual length. (For more details on this method, see John Allen's article: Check Spoke Tension by Ear. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted April 14, 2012 Report Share Posted April 14, 2012 I just use the rule that if I squeeze them and they don't flex, they're tight enough! Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 14, 2012 Report Share Posted April 14, 2012 I have mine rediculously tight because I hate spoke flex, only ever rounded nipples when I'd first started to build wheels and the only spokes I've snapped was a poorly(not built by me) built 2x disc radial nondisc front wheel. Quote Link to comment Share on other sites More sharing options...
dezmtber Posted April 14, 2012 Report Share Posted April 14, 2012 i used one of these at the othe rbikeshop i worked at dt tenso honestly a good wheel builder will find that the spokes are all pretty much spot on before fine tuneing the wheel with one of these. the old get the spoke length right and turn the nipples all one turn at a time till they feel positivly tight until the spoke flexes under your hand about 3mm ish Quote Link to comment Share on other sites More sharing options...
Ali C Posted April 14, 2012 Report Share Posted April 14, 2012 Wheel building isn't some black magic thing and stories of cassettes with the correct note for "some" wheels doesn't help shake it. If you have a good quality rim then all the spokes should sound the same, don't worry about getting them to a certain note or pitch, wheels vary from rims, hubs, spoke butting and number of crosses, so it's unlikely that two wheels will sound the same. If you have a lesser quality rim (most trials rims then) then you may have to tighten some spokes more than others to get a true wheel, this isn't ideal but it's just what happens, in this case the spokes won't all sound the same. Just concentrate on turning all the spokes evenly to start with, then see how true the wheel is looking and go from there. If the wheel is fairly true then you can work on getting a bit higher tension in the spokes, if it's all over the place, get it true (by tightening AND loosening the nipples) and go from there. I have access to a Parks spoke meter, but I rarely use it as it usually tells me what I already know from the feel and sound of the spokes while building. 1 Quote Link to comment Share on other sites More sharing options...
weebryan Posted April 15, 2012 Author Report Share Posted April 15, 2012 (edited) I agree with you Ali have trued a lot of wheels on past but that was built by a really good wheel builder and had a good tension to go by on good spokes but theses, i think a turn back and I could do it by hand really loose just need a base torque to start from to get a feel and then do rest Edited April 15, 2012 by weebryan Quote Link to comment Share on other sites More sharing options...
weebryan Posted April 16, 2012 Author Report Share Posted April 16, 2012 Well had a go at tighten spoke, feels way better no flex around corners and feels more sold and a better drive. Mr Ali your dead right about tensions being different some are looser than others and if I correct them it makes the wheel wobble so defo by feel and ping/squeeze spokes of a rough idea to what ones thanks ! Quote Link to comment Share on other sites More sharing options...
Maxx Posted April 16, 2012 Report Share Posted April 16, 2012 Another question about spoke tension, which one is better : - have very tight spokes in order to have the best transfer of energy - have a bit less tight spokes in order to have more rebound ? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted April 16, 2012 Report Share Posted April 16, 2012 Wheel building isn't some black magic thing and stories of cassettes with the correct note for "some" wheels doesn't help shake it. If you have a good quality rim then all the spokes should sound the same, don't worry about getting them to a certain note or pitch, wheels vary from rims, hubs, spoke butting and number of crosses, so it's unlikely that two wheels will sound the same. If you have a lesser quality rim (most trials rims then) then you may have to tighten some spokes more than others to get a true wheel, this isn't ideal but it's just what happens, in this case the spokes won't all sound the same. Just concentrate on turning all the spokes evenly to start with, then see how true the wheel is looking and go from there. If the wheel is fairly true then you can work on getting a bit higher tension in the spokes, if it's all over the place, get it true (by tightening AND loosening the nipples) and go from there. I have access to a Parks spoke meter, but I rarely use it as it usually tells me what I already know from the feel and sound of the spokes while building. This but also try and pringle you wheel on your lap every now and again to stress relieve it while building. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 16, 2012 Report Share Posted April 16, 2012 Another question about spoke tension, which one is better : - have very tight spokes in order to have the best transfer of energy - have a bit less tight spokes in order to have more rebound ? Have them normal tightness, it won't make a slight bit of difference. If they are loose it'll feel like shit. 1 Quote Link to comment Share on other sites More sharing options...
