brad1995 Posted April 9, 2012 Report Share Posted April 9, 2012 I was just wondering if anyone on here has used 2 master cylinders on their HS33 before instead of 1 master and 1 slave. Reason being that my slave cylinder is completely dead and i only have a spare master but to make it work i would need to use the shroud nut fittings as the crossover connections and i was just wondering if it would matter and affect performance and if anyone has been successful with this before? Thanks. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted April 9, 2012 Report Share Posted April 9, 2012 As long as all the connections fit it will be fine, by the way as far as I know the master cylinder is in the lever and the 2 others are slaves. Quote Link to comment Share on other sites More sharing options...
err Posted April 9, 2012 Report Share Posted April 9, 2012 2011 on maggies are like that anyway, and i ran my old set the way you described. i had my front one running thr m6/m6 cylinders and the m6/m8s on the rear, had them like that as i was using monty splitters Quote Link to comment Share on other sites More sharing options...
brad1995 Posted April 9, 2012 Author Report Share Posted April 9, 2012 Thanks guys ! I just said master cylinder because i found a bike shop online and they were calling the m6/m8 the master cylinder and the m6/m6 the slave cylinder but they only have the m6/m8 ones in stock and they are the older 2005 versions and there going for £15 each so if im changing one i might as well change the other and have a fresh new set. Quote Link to comment Share on other sites More sharing options...
old'scoolfool Posted April 9, 2012 Report Share Posted April 9, 2012 Thanks guys ! I just said master cylinder because i found a bike shop online and they were calling the m6/m8 the master cylinder and the m6/m6 the slave cylinder but they only have the m6/m8 ones in stock and they are the older 2005 versions and there going for £15 each so if im changing one i might as well change the other and have a fresh new set. i have a NOS master and slave (black old style) with crossover pipe i'll do for £25 if you want it? Quote Link to comment Share on other sites More sharing options...
