Magura Or Disk?
matley07
They all have their advantages and disadvantages, it also depends what brake you use with what disc or rim what pads the size of the rotor booster/no booster.
The tipical advantages with a disc are that they work in the wet and are quiet (if you like the quiet that is)
disadvantages include being contaminated very easily and can make high pitch sqeeling sounds when they dont work.
advantages with maguras are the sound (if you like that) they have more inital bite than a disc generally easier to bleed.
disadvantages, they can be harder to set up, if you use a grind it needs a grind every so offen, and they dont work in the wet.
Whatever you go for theres a good chance its not going to be perfect, nothing is. Just try and get a good setup to get a good brake.
Edited by Laurence--Trials
