Rear Hubs
Danh91
Hey guys,
New to the forum and trials! recently bought a 20" echo lite 09 and have found the rear hub is shot...
Been looking on tarty-bikes at a few different ones but wasnt sure what to get. Would i be ok going with Tryall hub or should i stick with an echo one?
Also would it make a difference the bike using snail cams?
Not looking for anything too expensive while im starting out.
Cheers
Dan
I don't know whats wrong with your hub but just in case you don't know; you can replace the bearings in most Hubs, if its an echo you can do it for definite. you can get them for a couple of quid off ebay or more expensive ones off tarty. Just check the code on the bearings.
  • 2 weeks later...
