Bearings Gone In Mtb Cranks?
1337 Trials
Hello. Was out riding tonight on my mtb and all of a sudden it felt as if the cranks were lose. I tried to rattle the crank arms but the whole crank arms/bottom bracket moved together inside the casing. I have the truvativ cranks with the external casing (quite a few years old now) so im not sure which bearings (if that is the bearings that are gone) that I will need.
/Thanks
Just checked it over and its the bb cup that has split. Im having trouble getting the left side bolt off (side the bb cup is cracked). Ive put some lube in the bottom and use a metal bar on the end of the hex key but the bolt is rounded off. I have no problem getting the drive side bolt out. Looks like im going to have to pay £30. £15 for the bb cups and £15 for the bike mechanic to drill the bolt out.
