Plastic Magura Pad Backings
Rourke
Hi I'm running magura pads on my hs33s and I was wondering if you guys new if the pad refills for the tnn engineering lmg would fit the plastic backings I already have.
Also Is there a big difference between the metal and plastic backings?
They will fit but only after a little modification.
And as for the CNC vs Plastic.
CNC backings are stronger, stiffer and supposedly aid brake performance. Look pretty pimp too.
Plastics just standard, but Ive never had any problems when I ran them in the past.
