Duncy H Posted March 24, 2012 Report Share Posted March 24, 2012 Rightio I'm fed up of my trialtech sprung tensioner rattling around so I wanna use a spoke tensioner. I am running a hex frame with a king hub in so it is quite tight for space between the dropouts. I am running 18:15 gear ratio and I reckon with a half link it would be quite tight but need tightening up with a spoke slightly. (bit wary of half links though) So yeh, any tips?? Quote Link to comment Share on other sites More sharing options...
cai Posted March 24, 2012 Report Share Posted March 24, 2012 Bend the tip of the spoke upwards so there's no danger of it getting stuck in your chain. Also make sure you coil the spoke around a bolt or around the axle at least a couple of times, this gives the tensioner a really good spring effect Quote Link to comment Share on other sites More sharing options...
CalopS Posted March 25, 2012 Report Share Posted March 25, 2012 Don't use a half link and just use a spoke tensioner? Not sure how you would fit one though having the hex without using a drill. Its easy on the old foreplays because the dropouts are full of holes Quote Link to comment Share on other sites More sharing options...
Duncy H Posted March 29, 2012 Author Report Share Posted March 29, 2012 Righ I've got a half link on now and the tension wants tightening up with a spoke, I've put a small washer between the frame and the king to give a bit more room but my attempts to make a decent spoke tensioner have been pants, anyone got some tips?? Quote Link to comment Share on other sites More sharing options...
