xTrials_Rider Posted March 20, 2012 Report Share Posted March 20, 2012 hi guys i have a problem, when i hopped off of a wall there was a small fence near where i landed and my level hit the fence. when i pull the brake in it works fine but it doesnt spring back out with ease, it jams, any solutions guys? thanks in advance Quote Link to comment Share on other sites More sharing options...
chris4stars Posted March 20, 2012 Report Share Posted March 20, 2012 which lever is it? the newer or older '05 model? (or older still?!) Quote Link to comment Share on other sites More sharing options...
xTrials_Rider Posted March 20, 2012 Author Report Share Posted March 20, 2012 which lever is it? the newer or older '05 model? (or older still?!) new 2011 two finger lever Quote Link to comment Share on other sites More sharing options...
Jeromboii Posted March 21, 2012 Report Share Posted March 21, 2012 new 2011 two finger lever You may of caught the body of the brake and it may of lost some fluid in it. I did this with my 2011 after 2 weeks of having it and it burst. I would check if it is leaking first. If it is then it might be worth trying to re-bleed it and see if it makes anything better. Quote Link to comment Share on other sites More sharing options...
xTrials_Rider Posted March 21, 2012 Author Report Share Posted March 21, 2012 You may of caught the body of the brake and it may of lost some fluid in it. I did this with my 2011 after 2 weeks of having it and it burst. I would check if it is leaking first. If it is then it might be worth trying to re-bleed it and see if it makes anything better. cheers guys the brake wasnt burst it was the tpa screw that has caught on to the level blade i sorted it now, cheers Quote Link to comment Share on other sites More sharing options...
Jeromboii Posted March 23, 2012 Report Share Posted March 23, 2012 cheers guys the brake wasnt burst it was the tpa screw that has caught on to the level blade i sorted it now, cheers Good job mate Quote Link to comment Share on other sites More sharing options...
