Andeee's Snowzonys V2 Curve
Andeee
Previously one of Damons frames he had. It even has "Damon W" wrote in tippex on the b.b lol
Here is a recent picture of my bike i thought id get a snap of it when the snow was here n this is the spec to this date!
Personally the best frame i have had so far.. i feel big progress already in my riding and feels a lot comfortable to ride and control. Video coming soon
I uploaded a pic of it ages when it had different stem n cranks
SPEC:
Ozonys V2 Curve
Neon Forks
Trialtech High Rise Stem
Echo Tr Bars
Trialtech b.b
Trialtech cranks with tartybikes bash ring n 18t screw on cog
DMR v8 pedals
Rear hs33 with heatsink yellows with magura clamps
front bb7 with xtr lever
sunline shroom grips
front wheel: trialtech square rim on hope pro 2 hub
rear wheel: onza alex wide rim 36h on pro2 trial hub
snail cams gold monty
red chris king headset
Tyres: Maxxis advantage 2.10 on the front and maxxis minion dual ply on rear.
Tubes: Tesco!
Current weight is around 10kg
post-11393-0-50963800-1332271196_thumb.j
post-11393-0-93552600-1332271226_thumb.j
post-11393-0-75336000-1332271315_thumb.j
post-11393-0-41460800-1332271325_thumb.j
Edited by Andeee
You already posted this last year http://www.trials-fo...curve-v2-stock/
Perfer Damon Watson's 2011 set-up. http://www.trials-fo...onys-curve-mk2/
Congratulations for your observation and taking the time and effort to search for those threads.
Hopefully my post below may help your confusedness basically the thread is an updated picture as i changed a few bits... CBA to re bump the existing thread
I uploaded a pic of it ages ago when it had different stem n cranks
Can you not read? I thought id make the words larger just for you to understand. Hope this helps matey
Edited by Andeee
How does the rise of your bar and stem combo feel? Did you used to have it lower?
For this frame it feels amazing... exisiting frames i have had which had lower b.b i ran a 130x15 stem. but now i like high frames with high stems they seem to be the best combo for control and power
