Square Taper To Isis Set Up
D Rock 45
Why you wanna change?If everything is working,just save your money,you have good setup as it is ;)
at the moment i have two tight spots, due to my hub and crank arms not having centerd threads it really crunches when both of them are out of line, and i cant solve it by loosening the chain, it just goes stuipidly loose
Edited by D Rock 45
isis cranks tend to out last square taper cranks dramatically, mostly the isis interface is way less prone to round off, which can be a problem with cheap square taper cranks, plus the range of isis stuff is way better, i wouldn't consider a bike without isis. don't worry about people saying keep wha you've got, it's an upgrade you'll make at some point in riding, might as well get it over with...
  • Like 1
