Rear Axle
I'm not sure which to buy. I've got an Onza T-Raptor, and it had the standard onza quick release on the back. It measures 184mm from one end to the center of the quick release, 167 from end to the quick release nut thing, might be a bit stretched seeing as I snapped it by overtightening/the nut slipping into the tensioner hole. And about 4mm diameter. Wouldn't mind switching to a nut axle, any suggestions? Cheers.
Edit: I think I might mean rear skewer...
Edited by LordAssworthMcThor
Im going to assume you've got the standard Onza half phat/full phat wheels that come ona t-raptor... in that case you just need to go to a bike shop and get a threaded axle and cone spanners and switch it over :) If you post up some pictures ill be able to give you some more advice .
Cheers, Alex
