robbie-woods Posted March 9, 2012 Report Share Posted March 9, 2012 okay its really getting on my nerves now even if i pull the rear brakes a tiny bit it squeeks right away and when i put it on full it sounds awfull! ive got magura brakes with yellow pads if that makes any difference, there is loads of black rubbish over the rim but im finding it hard to get off. is there anything else that could cause them to squeek sooooo much? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted March 9, 2012 Report Share Posted March 9, 2012 A nice loud squeek is a good thing! In simple terms - it means your brake is working. The black stuff will most likely be tar, to make the brake bite. But tar is rubbish as once it gets wet you'll be slipping and sliding everywhere. Best thing to do is grind your rim. Lots of topics about rim grinds. Quote Link to comment Share on other sites More sharing options...
robbie-woods Posted March 9, 2012 Author Report Share Posted March 9, 2012 ahh okay just gets on my nerves after a long ride haha, thanks i will have a look at rim grinding and see if i fancy giving it a go., cheers buddy Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted March 9, 2012 Report Share Posted March 9, 2012 I have magura's too and heatsink yellows and grinds on both.. I like the bite and sound but my neighbours don't..but yeah it is a gooood thing Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted March 10, 2012 Report Share Posted March 10, 2012 okay its really getting on my nerves now even if i pull the rear brakes a tiny bit it squeeks right away and when i put it on full it sounds awfull! ive got magura brakes with yellow pads if that makes any difference, there is loads of black rubbish over the rim but im finding it hard to get off. is there anything else that could cause them to squeek sooooo much? Robbie the noise is meant to be there Quote Link to comment Share on other sites More sharing options...
William trials Posted March 10, 2012 Report Share Posted March 10, 2012 It's supposed to sound, this is because friction when you brake. This is only a good thing, and means that your brake works good. The black thing on you'r wheel is tar, I would reccomend you to use a angle grinder and grind the rim hope this helps//william Quote Link to comment Share on other sites More sharing options...
pogo Posted March 10, 2012 Report Share Posted March 10, 2012 If you dont want any noise get a disk, as people have already said, it's supposed to make that sound, embrace the noise. Quote Link to comment Share on other sites More sharing options...
