Aii_Aitch Posted March 9, 2012 Report Share Posted March 9, 2012 Hey, how can I find out what length spokes I'll need for any hub and rim combo? Right now, I'm thinking of splashing out on a custom rear wheel. How will I know that I've bought the right length spokes to fit the 19" rim? I know that I should be measuring from flange to nipple hole (or whatever the proper name is), but doesn't how you thread the spokes also make a difference to the length you need? Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted March 9, 2012 Report Share Posted March 9, 2012 (edited) what rim and hub are you looking to get? you need to know.. the Rims ERD the hub flange diameter and the hub centre to flange diameter all which will/should be stated on the website you buy from. once you know all these you can put the numbers into the dt swiss spoke length calculator and it will tell you what length you need. edit: you should run a 3-cross lacing pattern on both sides of the wheel if you can. the strongest pattern. actually maybe 4-cross but you might as well do 3-cross. Edited March 9, 2012 by Carlperkins Quote Link to comment Share on other sites More sharing options...
Aii_Aitch Posted March 9, 2012 Author Report Share Posted March 9, 2012 Thanks! I take it that a 3-cross and a 4-cross will both work on a 32H rim/hub? I'm not sure where the information on the ERD is? In fact, what is an ERD? Something something diameter? rims to choose from: http://www.tartybikes.co.uk/19_inch_rims/echo_tr_rear_19_inch/c517p10713.html or http://www.tartybikes.co.uk/19_inch_rims/monty_221_rear_19_inch/c517p2155.html and a closed fixed disc hub. probably either: http://www.tartybikes.co.uk/116mm_fixed_hubs/bonz_expert_rear_disc/c62p11743.html or http://www.tartybikes.co.uk/116mm_fixed_hubs/echo_tr_rear_disc/c62p10707.html or http://www.tartybikes.co.uk/116mm_fixed_hubs/rockman_bub_rear_disc/c62p10817.html Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted March 9, 2012 Report Share Posted March 9, 2012 If you're buying off Tarty just add in the hub/rim name in the comments box when you check out and they're send you the right size spokes. Quote Link to comment Share on other sites More sharing options...
Aii_Aitch Posted March 9, 2012 Author Report Share Posted March 9, 2012 hah! love tarty. sorted. thanks, lads. Quote Link to comment Share on other sites More sharing options...
