Freewheel Movement
dangerous bry
As I pedal backwards the freewheel wobbles/moves as if it is not inline it also makes the chain go tight then slacken off slightly, yet when freewheeling forward it seems to stay true. Is this normal? Or is there something wrong? Everything is tight and secure, and freewheel is not cross threaded on the crank. If someone could enlighten me it would be much appreiciated.
well, when you move your pedals backwards it's totally normal that the chain slacken a bit, then tighten itself, I don't know why but it's normal.
But i don't know why i wobbles that much, try to: tighten your crank bolts, or tighten the lockring on the freewheel.
hope this helps// william :)
