Echo Lite 2011 And Try-All Rear Disc Hub.
bike_dummie
Hi,
As the title says i am wondering if the Try-All pre-built wheel is compatible with an Echo lite 2011 frame (the one with magura mounts aswell) as it says in the description, Recommended for rim brake use due to the slightly non-standard position of the disc mount, but it says nothing about this in the decription of the hub?
Basically what I want to know is will this work or will I have spacing issues? Is there any modifications I can do as I don't want to waste my money.
it seems like they will :P
Seems? Are you retarded?
On a more serious note, i have the try all hub infront of me, and i think what tarty are referring to is that the disk mount is spaced out quite far out on the hub, so the disk would run very close to the frame.
Apart from that, the hub fits in a 116mm frame fine.
