Front Radial Wheel
tipek
Hi there
I have put together the ultimate radial front wheel
Does this charge echo tr (91 g)
http://www.tartybikes.co.uk/front_non_disc_hubs/echo_tr_non_disc/c86p10704.html
and I do not know if I should put this echo TR rim (680 grams)
http://www.tartybikes.co.uk/26_inch_front_rims/echo_tr_front_26_inch/c518p10714.html
or the echo SL (620 g)
http://www.tartybikes.co.uk/26_inch_front_rims/echo_sl_front_26/c518p10598.html
I have stainless steel spokes,
I want to have a lightweight front wheel where the brake good brakes,
what combination of components would you recommend? (street driving)
sorry for my English google translate :)
thank you guys for coments :)
yes I want it to STOCK,
I have a TR echo hub and rim do I need to advise him
which you think is best if it is a totally?
all are well? :) The radial spokes? :)
Radial spokes are fine on the front, you dont need much strength.
id personally go for the try-all/trialtech square/cirle hole. Strong rims that hold a grind well
when the weaker spokes are radially retracted,
destroy the wheel driving to jumping into the front wheel? front gaps?
strongly attract spokes could not destroy the hub ?
