Building My Own Wheel
williams
hi, well im going to build my own wheel with my rear 2010 onza pro rim. Im going to use Black spokes with a "Trialtech race sealed hub" which has 32 holes. Should i buy 2 different spoke lengts for the drive side etc. or can I just use to of the same size? and shold i do 3 or 4 cross? please help.
many thanks// william!
Edited by williams
3X will be the easiest pattern to learn if it's your 1st build. As for spoke lengths it will vary between hubs (different flange sizes/offsets) There are various spoke length calculators over the internet, failing that tarty will normally calculate it for you when you order spokes from them.
okej, thanks for the quick reply! I suppose i have 3 cross now, but i will stick to that :) im going to order it from tartybikes so they have to wotk it out for me :)
have a nice day! // william
3X, but if you never have built a wheel before, i would advise you dont make this one your first.
Practice on an old crappy wheel first so you get the lacing sorted and a good guide is http://sheldonbrown.com/ Knows his stuff and is the only guide i have ever used.
What he said. Another pointer i can give is to only tighten each spoke no more than half a turn at a time, this will reduce the risk of disaster!
