Brake Cable Through Headset?
Conradm94
You will need a top-cap which has two holes in it, or you could possibly drill your current one.
One hole for removing top-cap, the other for the cable.
Remove the front brake cable from either its caliper or lever, which ever is easiest.
Then thread the cable through the assembled top-cap/fork/frame/headset and reattach it to the caliper/lever.
Then either re-bleed or adjust your cable so the brake works nicely, job done!
Edited by AndrewEH1
