Freewheel Placement?
Conradm94
just get a freehub?
Any justification for getting a guy to pay for a hub, new spokes and a rebuild for what would be an identical setup but with less engagement?
If it works as it is then leave it, if you must you can consider getting different cranks that will allow a front freewheel to be used, the only alterations it will make would be the availability of different gear ratios and saving a bit of weight
i have always thought they are best on the front however this depends on the gear ratio i think the rear mounted would probably be better on the 24
And i agree if it's not broke dont fix it
To fit a freehub would be expensive and i see no advantage
