U Break Adaptor
shansen
hey guys
i know this is all about trials and that its a bmx question but really need your help
dose anyone know where i can get a ubreak to vbreak adaptor, ive been looking about and i cant find any but ive seen some pictures of one on google images.
your help would really be appreciated because ubreaks suck :)
thanks seb.
Surely this will not work, a) bearing in mind they mount higher then the arms would hit the bosses for u brake, you could combat this by chopping them off yes but then you also have to take into account these are designed to fit the tube thickness of a fork, no bmx rear triangle no matter how beefy will be thick enough to accommodate these.......
Depends on the bmx frame, These would easily fit on my 04 hoffman i have laying around in my shed.
I looked into it ages ago and found out about it on pinkbike. Basically, no, it cannot be done.
Just forgot to put in my original post, that was a quick search, but there are mounts the fit on ally and carbon roadie forks, there your best option.
Set up your U good enough there just as good as your average V.
Are you serious?
A well set up odyssey evo with decent pads works wonders. Although not as good as a maggy, which is why I brazed some 4 bolt mounts onto the other side of my seatstay works an absolute treat!
You can get v brake plates which someone posted above but I've never seen a U to V adaptor.
thanks for all the good feedback guys, but reading it my idea wont work then. I was only looking for a cheap solution for getting a good break on my bmx its not worth all that much so im not going to spend loads on a good u break, so might go slap on some tar or something.
but thanks again
seb.
I have many, many years ago, it was shit.
