dannytrialskid Posted February 29, 2012 Report Share Posted February 29, 2012 (edited) Bled my brakes today, because I split my hose. Got oil on my rims. It's now too late to grind my rim, and I am going on a ride tomorrow that is over an hour away, so it will be too early to grind my rims in the morning when I leave. How can I get the oil off of my rims? - The brake is utter shit at the moment, doesn't hold anything, doesn't make an noise when I pull in brake. I have soaked my pad in hot soapy water to get the grease off then wiped them down and went over the top layer with a file. I'll try anything right now, because I don't want to go a ride where my brake just doesn't work! Edited February 29, 2012 by dannytrialskid Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted February 29, 2012 Report Share Posted February 29, 2012 Suppose some paint stripper would work okay, just dont leave it there too long, and I'd only do It on anodized rims. Well that's what I've done in the past. Quote Link to comment Share on other sites More sharing options...
AndrewEH1 Posted February 29, 2012 Report Share Posted February 29, 2012 Bled my brakes today, because I split my hose. Got oil on my rims. It's now too late to grind my rim, and I am going on a ride tomorrow that is over an hour away, so it will be too early to grind my rims in the morning when I leave. How can I get the oil off of my rims? - The brake is utter shit at the moment, doesn't hold anything, doesn't make an noise when I pull in brake. I have soaked my pad in hot soapy water to get the grease off then wiped them down and went over the top layer with a file. I'll try anything right now, because I don't want to go a ride where my brake just doesn't work! Fairy Liquid, warm water + brush! Then hose it down a little. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted February 29, 2012 Author Report Share Posted February 29, 2012 Fairy Liquid, warm water + brush! Then hose it down a little. What sort of brush? Quote Link to comment Share on other sites More sharing options...
AndrewEH1 Posted February 29, 2012 Report Share Posted February 29, 2012 (edited) What sort of brush? Old dish brush? Something like that. Same process as your pads but on a larger scale. Edited February 29, 2012 by AndrewEH1 Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 29, 2012 Report Share Posted February 29, 2012 A grinder works pretty good. All other methods I've ever tried don't work. It never goes back to being the same. meths may sorta work? Quote Link to comment Share on other sites More sharing options...
Chris Borneo Posted February 29, 2012 Report Share Posted February 29, 2012 If it was me I'd have a go with some meths and an old toothbrush. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted February 29, 2012 Author Report Share Posted February 29, 2012 If it was me I'd have a go with some meths and an old toothbrush. What's meths? Quote Link to comment Share on other sites More sharing options...
Chris Borneo Posted February 29, 2012 Report Share Posted February 29, 2012 Oh yeah, might take a bit of time for your pad to bed in again if you've filed it. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted February 29, 2012 Author Report Share Posted February 29, 2012 Oh yeah, might take a bit of time for your pad to bed in again if you've filed it. I didn't exactly file it, literally just had a few strokes over the top, to be honest I don't think it even done anything :L Quote Link to comment Share on other sites More sharing options...
AndrewEH1 Posted February 29, 2012 Report Share Posted February 29, 2012 What's meths? Meths - methylated spirits, basically a household(ish!) cleaner. Quote Link to comment Share on other sites More sharing options...
Chris Borneo Posted February 29, 2012 Report Share Posted February 29, 2012 Methylated spirits. That purple shit. 1 Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted February 29, 2012 Author Report Share Posted February 29, 2012 Old dish brush? Something like that. Same process as your pads but on a larger scale. 20 minutes later, and it cleaned my rims a bit. Brake is still shite. Brakes were perfect before I bled them. So it's either shit on the rims, or on the pads. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 29, 2012 Report Share Posted February 29, 2012 How early do you need to leave? I'd just say f**k it and annoy people for 10 mins in the morning. Some pads can kinda 'soak' up the oil too, so if you have any spares may be wirth throwing them on after you grind to stop it contaminating again Honestly, like I said before, its a pain in the arse and never works to clean the rim. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted February 29, 2012 Author Report Share Posted February 29, 2012 (edited) How early do you need to leave? I'd just say f**k it and annoy people for 10 mins in the morning. Some pads can kinda 'soak' up the oil too, so if you have any spares may be wirth throwing them on after you grind to stop it contaminating again Honestly, like I said before, its a pain in the arse and never works to clean the rim. Leaving at 9/9.30am, I suppose it might be ok by then. Edited February 29, 2012 by dannytrialskid Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 29, 2012 Report Share Posted February 29, 2012 Clean your rim with thinners, or turps, give it a fresh grind, boil the pads and scrun them on some sand paper to take the top layer off, should be fine Quote Link to comment Share on other sites More sharing options...
trials_pimp Posted February 29, 2012 Report Share Posted February 29, 2012 Stop at halfords on the way and get a can of brake cleaner. Spray on rims and leave it alone. That will get rid of anything on them. Then sand the pads down and hope they arent too contaminated. Quote Link to comment Share on other sites More sharing options...
Chris Borneo Posted February 29, 2012 Report Share Posted February 29, 2012 Hopefully you can get it sorted but if it's still not right in the morning, don't let it wreck your ride. Most people would consider my brake (I only have one at the moment) to be shocking but it does for me. Just work with what you've got. You might learn something new. Good luck. Clean your rim with thinners, or turps, give it a fresh grind, boil the pads and scrun them on some sand paper to take the top layer off, should be fine Just out of interest, what does boiling the pads do? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 29, 2012 Report Share Posted February 29, 2012 Leaving at 9/9.30am, I suppose it might be ok by then. Anyone who is worth giving a shit about is at work by then (apart from firemen. But whatever). Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted February 29, 2012 Author Report Share Posted February 29, 2012 (edited) don't let it wreck your ride Just out of interest, what does boiling the pads do? If only you knew me. Me + Shit brake = Angry! But I suppose it will have to do. I have been looking forward to this ride for ages! Then my hose decides to give in. Bike 1 - 0 Me Fix brake, contaminate rims and pads. Bike 2 - 0 Me Edited February 29, 2012 by dannytrialskid Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted March 1, 2012 Report Share Posted March 1, 2012 Just out of interest, what does boiling the pads do? Boiling water cleans the pad, and gets anu crap out of it. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted March 1, 2012 Author Report Share Posted March 1, 2012 Update to those of whom are interested. Grinded my rim this morning and brake is insane! Quote Link to comment Share on other sites More sharing options...
