A Little Bit Of Help
Jeromboii
Have seen a topic on side hopes already but got a quick question to ask as the other topic didn't answer my question.
I used to side hope to the right while kicking with the right foot. Then changed and went to the left while still kicking with the right pedal. I used to be able to side hope about 6 and back 5 blue pallets when I used to do it the wrong way. Now I can only do 4 pallets doing it to the right way(kicking right going left). When I do this technique I always put my front tyre first and swing my back tyre up. Is that the right thing to do ? or do i want to land on both wheels at the same time ? Its only 4 pallets though ?
Help would be appreciated :)
Its completely up to you really but the correct way for you would be left and kicking with your right foot. This helps as you can get closer to the wall and won't clip your pedal!
Thanks mate, Do I land the front tyre first then swing the back up ?
Well its two different techniques really, It looks smarter and smoother if you do two wheels but if your struggling front is just as good and i think you can get a little more hight when learning =D
