cardenas_26trials Posted February 28, 2012 Report Share Posted February 28, 2012 Got the frame about one month ago, also changed the rear rim and hub. Zoo! lynx 2012 frame Echo urban v-brakes fork Echo TR rim on ZHI disc rear hub at the back with Maxxis Creepy Crawler Echo TR rim on Echo TR non disc at the front with Kenda Small Block 8 (1.95) Echo 72 points freewheel Echo old bashring Echo ISIS cranks Echo TR lever with Magura cylinders, Echo 4 bolt booster and Atomz pads Amoeba stem and handlebars Will change stem and bars tomorrow... cranks, pedals, chain, bashring and rear brake also will be changed soon. Cheers from Chile 1 Quote Link to comment Share on other sites More sharing options...
pablotrial Posted March 2, 2012 Report Share Posted March 2, 2012 apenas la vi pense que era de algun streetero tgs bestia jajaja muy linda. saludos desde argentina... a cambiar ese manubrio Quote Link to comment Share on other sites More sharing options...
trials_and_tribulations Posted March 13, 2012 Report Share Posted March 13, 2012 So how are you liking this bike? Quote Link to comment Share on other sites More sharing options...
cardenas_26trials Posted March 14, 2012 Author Report Share Posted March 14, 2012 apenas la vi pense que era de algun streetero tgs bestia jajaja muy linda. saludos desde argentina... a cambiar ese manubrio ajajaja nada de bestia por el momento, pero de a poco se mejora no? el manubrio you lo cambié, ahora uso un Neon 7075 muy cómodo! saludos So how are you liking this bike? The frame feels and looks pretty solid, in comparison of other Deng's frames like the Echo Lite or Sl. Geo is also very nice, it's my first time riding something with such a high BB so it feels quite new to me. Need to buy a new chain or put in a half-link quickly, the one I'm using now has stretched so much it changed the wheel base at least 1,5-2mm which makes me feel the bike a bit long. The biggest problem was the chain hitted the upper chainstay very badly, so had to add some spacers of one side of the hub and run the chain extremely tight but well, after all is a great frame, hope it lasts long cheers! Quote Link to comment Share on other sites More sharing options...
trials_and_tribulations Posted April 8, 2012 Report Share Posted April 8, 2012 The biggest problem was the chain hitted the upper chainstay very badly, so had to add some spacers of one side of the hub and run the chain extremely tight you I have been having this issue aswell, it came stock with a 13t cog on the rear with the teeth centered on the cog. I'm going to order a 12t trialtech cog with the teeth at the edge and flip it so the teeth are closer to the center of the hub, but untill I get it I may try your idea. Quote Link to comment Share on other sites More sharing options...
stunt man t Posted April 8, 2012 Report Share Posted April 8, 2012 you I have been having this issue aswell, it came stock with a 13t cog on the rear with the teeth centered on the cog. I'm going to order a 12t trialtech cog with the teeth at the edge and flip it so the teeth are closer to the center of the hub, but untill I get it I may try your idea. make sure there is enough room for the chain not to rub on the spokes though, i had this problem aswell Quote Link to comment Share on other sites More sharing options...
