Get Out And Replace Starnut?
dannytrialskid
Best way to get it out, get something long that fits in the steerer but not through the star nut, and hammer it out from the top.
This works much better on steerer tubes that don't get narrower to the bottom. Echo steerer tubes do...
Best way to get one in, put a bolt in the top and be careful. It'll straighten up a fair bit so you have a bit of a margin for putting it in wonky. You're best to straighten it up as best you can before the second star goes in. Then you can whallop it.
you can also take a drill, you just drill in the star nut screw hole with the sizes 6,8,10,11,12 just keep drilling and get up in size, and when you drill with the 12mm drill the whole star nut should just fell apart.
and for getting it in just take something that almost have the same shape as the starnut, and just hammer gently on it. be sure to keep it straight!
hope this helps! :)
Edited by williams
I got the Try-All 2011 forxx and at the bottom of the forks the hole is smaller than what the diameter of the steerer tube end is.
So I can't hammer it out.
How else do I get it out -.- ?
It's possible to hammer them back up but it's very difficult. You have to beat the points of the star away from the steerer. I managed to do it in a pair of echo forks but it took AGES. Seriously ages.
I beat it so much it ended up turning around inside the steerer tube and it came out looking pretty unusable.
Edited by Revolver
