King Hub Sounds Strange.
Azarathal
Basically, when I spin the wheel the king is loud although it makes a strange rattling noise. When I'm actually on the bike the hub is absolutely silent, it enganges nicely and doesn't skip but I'm not sure whether to be worried about the changes in noise and the rattling sound when spinning fast.
Not the best of videos but at least you can get some idea.
Anyone know what could be wrong?
Rattling could be lose spokes if it happens when your on it, i've had that before, it sounds like one of those kids bikes with plastic bead things on the wheel. Don't know about the quiet thing though, try taking it apart checking there's no build up of crap in there, clean everything, then put it back together? Thats all I can say?!
No its definitely something inside the hub itself as it only happens when span fast rather than ridden fast, I know the sound loose spokes make.
I've had the cassette body + axle out and sprayed GT85 in and it didnt make the slightest bit of difference, my LBS doesn't have the king tool but a friends one does so I'm going to borrow that and have it apart properly, I'd knock the bearing out if it wasnt already slightly notchy.
