Blake Posted February 20, 2012 Report Share Posted February 20, 2012 Was tightening my bottom bracket on a ride the other week when chris borneo was saying how much torque it should be done up with, he reckoned it was around 40NM but wasn't entirely sure. Of course my bottom bracket has loosened again so I was going to use some thread glue along with my dads torque wrench, but what torque should I do it up to? Thank you! Quote Link to comment Share on other sites More sharing options...
Sam T Posted February 20, 2012 Report Share Posted February 20, 2012 Just do it as tight as you think you can go with a decent length bar without stripping the threads. If your not a girl it should be tight enough.. Quote Link to comment Share on other sites More sharing options...
Rockman Posted February 20, 2012 Report Share Posted February 20, 2012 anti-seize then 40Nm Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted February 20, 2012 Report Share Posted February 20, 2012 To be honest, I've never torqued up a Bottom bracket. I use a 1/2inch ratchet and give it a good nip. I've never had one come loose on me. Personally I wouldn't use threadlock, could do more damage that good Quote Link to comment Share on other sites More sharing options...
Chris Borneo Posted February 20, 2012 Report Share Posted February 20, 2012 Really surprised that's come loose already although I'll bet it stayed tight longer for havin the drive side done up tight. Starting to think thread locker might be a bit overkill and might be a real pain to get out. It really shouldn't need it. Might be worth giving all the threads a clean and a check over and then put it back in with some copper grease. Then give it some with the torque wrench. If the threads are all good, i'd give it about 40ft lb. Quote Link to comment Share on other sites More sharing options...
Blake Posted February 21, 2012 Author Report Share Posted February 21, 2012 Yeah i think it's because we only had my Allen key to do it up with chris Unless it's the bearings creaking.... Quote Link to comment Share on other sites More sharing options...
