AndrewEH1 Posted February 20, 2012 Report Share Posted February 20, 2012 Need to replace my chain, usually I would just pop into a LBS and buy any old one. I need a 10 speed chain, any recommendations? Quote Link to comment Share on other sites More sharing options...
Robwalker Posted February 20, 2012 Report Share Posted February 20, 2012 How much money do you want to spend - and what sort of bike? Quote Link to comment Share on other sites More sharing options...
AndrewEH1 Posted February 20, 2012 Author Report Share Posted February 20, 2012 Money isn't a massive issue, and it's a Five it that helps. I haven't had to buy a proper chain in years. Quote Link to comment Share on other sites More sharing options...
Robwalker Posted February 20, 2012 Report Share Posted February 20, 2012 Normal call would be to go with whatever groupset you're running, but sram and shimano are relatively good when mixing equipment. Good deals on CRC at the moment http://www.chainreactioncycles.com/Models.aspx?ModelID=53864 Quote Link to comment Share on other sites More sharing options...
ZeroMatt Posted February 20, 2012 Report Share Posted February 20, 2012 Can't fault the X10 93 from KMC. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted February 29, 2012 Report Share Posted February 29, 2012 Would just like to point out that in my experience the (expensive) zinc coated versions of the Sram chains don't seem to prevent corrosion significantly longer than the uncoated ones. Ensuring its clean, GT85/WD40'd after washing and lubed is hugely more effective. No experience with other makes but I've heard good things about KMC chains. Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted March 1, 2012 Report Share Posted March 1, 2012 I swear by Sram chains, and Shimano Cassettes. Any one really from the Sram PC range will do. Like said above, after use, give it a damn good clean to get the dirt/ oil off, then simply spray with WD40 to disperse the water. Leave for a few hours, then use a good wet lube. Quote Link to comment Share on other sites More sharing options...
