Brakes ( Where Is The Diffrent )
Przemo
The Tech Evo bit just refers to the updated Tech lever. It's now got a little cam system instead of the previous type of push-rod/piston setup at the lever, which Hope claim increases power (...somehow?), but makes everything a bit smoother.
With Hope brake naming, the first bit always refers to the lever and the second the caliper, so the Tech V2 is a Tech lever with V2 caliper. The Tech Evo V2 is the Tech Evo lever with a V2 caliper. Same goes for the Tech Evo X2, and so on.
  • Like 1
