tdubz Posted February 16, 2012 Report Share Posted February 16, 2012 Frame: zhi 26inch Fork: cannondale fatty r Stem: because Bars: tarty Front wheel: d521 drilled on deore hub with grind Rear wheel: drilled rim on hope pro 2 with grind Tyres: echo Cranks: echo Pedals: welgo Front brake: avid front brake with avid lever Rear brake: magura hs33 water bled with heatsink pads Headset: fsa pig sealed Bb: trialtech Chain: halflink Tensioner: home made!!!!!!!! Future plans New front Pads Different ring setup to gain better chain adjustment to eliminate bodged tensioner New front and rear tyres but want light ones All comments welcome Quote Link to comment Share on other sites More sharing options...
Jo Prattley Posted February 17, 2012 Report Share Posted February 17, 2012 looks coool!! i was using a half link on mine with an 18 15 ratio butg i have bought a new chain and can just about get away with running it without (i am using tnn clamps) Quote Link to comment Share on other sites More sharing options...
tdubz Posted February 17, 2012 Author Report Share Posted February 17, 2012 Wat rear hub you running? Wat did you change to? Are you running snailcams? Quote Link to comment Share on other sites More sharing options...
alistair14 Posted February 17, 2012 Report Share Posted February 17, 2012 Wat rear hub you running? Wat did you change to? Are you running snailcams? Read. The. Spec. -facepalm- Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted February 17, 2012 Report Share Posted February 17, 2012 Read. The. Spec. -facepalm- Its his bike - he is asking Joe about his set up on the same frame. .FACEPALM. 7 Quote Link to comment Share on other sites More sharing options...
Ben Swales Posted February 17, 2012 Report Share Posted February 17, 2012 Read. The. Spec. -facepalm- Its his bike - he is asking Joe about his set up on the same frame. .FACEPALM. Quote Link to comment Share on other sites More sharing options...
tdubz Posted February 17, 2012 Author Report Share Posted February 17, 2012 Wat rear hub you running? Wat did you change to? Are you running snailcams?I was asking joe about his setup Quote Link to comment Share on other sites More sharing options...
trialparts Posted February 17, 2012 Report Share Posted February 17, 2012 Where you buy it ? What was price ? Quote Link to comment Share on other sites More sharing options...
Jo Prattley Posted February 17, 2012 Report Share Posted February 17, 2012 Wat rear hub you running? Wat did you change to? Are you running snailcams? im running an echo tr with a titanium echo sprocket, im now running the bigger kmc chain z5somethingorother 1/8 it is ... and yeah monty snail cams but i reckon if you ran without the snailcams it would be perfect at an 18/15 ratio .. but i havnt had the time to try it out yet Read. The. Spec. -facepalm- brilliant ..... Quote Link to comment Share on other sites More sharing options...
tdubz Posted February 17, 2012 Author Report Share Posted February 17, 2012 Issue i have is the hope hub proximity to the location of snail cams Quote Link to comment Share on other sites More sharing options...
dann2707 Posted February 17, 2012 Report Share Posted February 17, 2012 Its his bike - he is asking Joe about his set up on the same frame. .FACEPALM. Ahhhhahahahahaaaaaa Brilliant. Quote Link to comment Share on other sites More sharing options...
Paperclip Posted February 17, 2012 Report Share Posted February 17, 2012 (edited) Where you buy it ? What was price ? Your a DICK Edit: Bike looks well, shame about gear ratio mine was spot on with 18/15 and I have a year old chain. Edited February 17, 2012 by Seabasss 2 Quote Link to comment Share on other sites More sharing options...
Jo Prattley Posted February 17, 2012 Report Share Posted February 17, 2012 Your a DICK Edit: Bike looks well, shame about gear ratio mine was spot on with 18/15 and I have a year old chain. +1 who are you and why (if you were so desperately after one to comment on anything zhi related) havnt you already purchased one ? Quote Link to comment Share on other sites More sharing options...
tdubz Posted February 17, 2012 Author Report Share Posted February 17, 2012 Your a DICK Edit: Bike looks well, shame about gear ratio mine was spot on with 18/15 and I have a year old chain. Its because im running pro 2 hub but i am very reluctant to change from a hope Quote Link to comment Share on other sites More sharing options...
alistair14 Posted February 18, 2012 Report Share Posted February 18, 2012 (edited) Haha wow i got par'd I didn't see the names where the same, i just saw the noobish comments :L sorry! Edited February 18, 2012 by alistair14 1 Quote Link to comment Share on other sites More sharing options...
trialparts Posted February 18, 2012 Report Share Posted February 18, 2012 I want to see someone in real life and say us some bad words.. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted February 18, 2012 Report Share Posted February 18, 2012 I hear threats are a pretty good way to drum up new business. Nice one. 2 Quote Link to comment Share on other sites More sharing options...
Jo Prattley Posted February 18, 2012 Report Share Posted February 18, 2012 lets not turn this thread into an argument kids !! Quote Link to comment Share on other sites More sharing options...
