Rob. Posted February 15, 2012 Report Share Posted February 15, 2012 ok so i just put a tryall symetrik bashring on my crank with an echo sl freewheel and my problem is that the freewheel is really tight to engage, its touching the bashring dead on. Can anybody help me with some use full advice Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 15, 2012 Report Share Posted February 15, 2012 What cranks? The symetriks have a cut out for the crank to sit into, is it sitting in the recess? Quote Link to comment Share on other sites More sharing options...
Rob. Posted February 15, 2012 Author Report Share Posted February 15, 2012 What cranks? The symetriks have a cut out for the crank to sit into, is it sitting in the recess? tryall cranks, i know which bit you mean, i loosened it and put it back on but when i tighten it it trys to move. it is not being tight anymore but i feel when i go ride later and the freewheel goes onto the crank tigher it may happen again. rbo. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 15, 2012 Report Share Posted February 15, 2012 Hmmm, I've run try-all cranks with the symetrik and an SL for years with no problems. Is it worth putting a pic up? As long as theres no washers/spacers in there and the crank sits nicely in the cut-out I can't see where there would be an issue. If you put the bash on the crank nicely in the cut-out, put the freewheel on and tighten it up by hand so there is nowhere for the bash to move, that should work to stop it jumping out of the cut-out? Quote Link to comment Share on other sites More sharing options...
Rob. Posted February 15, 2012 Author Report Share Posted February 15, 2012 Hmmm, I've run try-all cranks with the symetrik and an SL for years with no problems. Is it worth putting a pic up? As long as theres no washers/spacers in there and the crank sits nicely in the cut-out I can't see where there would be an issue. If you put the bash on the crank nicely in the cut-out, put the freewheel on and tighten it up by hand so there is nowhere for the bash to move, that should work to stop it jumping out of the cut-out? if the freewheel starts going stiff again i will give that a go, thanks for help. Quote Link to comment Share on other sites More sharing options...
mr.tattoo Posted February 15, 2012 Report Share Posted February 15, 2012 i had this while ago, cnt rem what cranks etc but i changed freewheel and it was fine, my freewheel was rubing on the lip of the bash despite it being flat. Quote Link to comment Share on other sites More sharing options...
