Homemade Truing Stand !
JamieWilliams
I thought of this a while ago... cheaper and easier. Sorry for bad photo, taken with my phone at night.
Put a zip tie around your fork/chainstay and rotate it to adjust how close the end is touching the rim. True accordingly.
I use this to check if my wheels are true or not, and use them to true out small buckles. This method doesn't get you a evenly dished wheel though, unless you have a good eye or have something else to do the dishing.
I've actually built a few wheels for some friends and myself using this method, none has complained about a buckled wheel so I guess it works fine.
Edited by weirdoku
