Tnn Cnc Backing With Echo Rim Brake
TommyBrew
Tried fitting some Tnn backed pads to my echo brake today and although they fit inside the cylinder sleeves, it wouldn't push onto the little knobbly bit and stay on. Will I have to get a smaller Inside diameter o-ring for the backing?!. The only thing I could do was remove the oring but they'll just fall straight off obviously, Any suggestions?!. Thanks, tom
