Hope Tech X2
staryarm69
hi iv got a hope x2 front disc brake and would like a bit more power and hold, its a 160mm rotor the standard one and its had nothing done to it yet. im thinking first steps would be some new pads like the ebc red or superstar Kevlars but im still pretty new to disc so any advice is welcome.
also does any one make an after market lever blade for the tech lever as the standard one isn't that nice in my opinion
the tech x2 uses a smaller brake pad to the trial or v2.
best you could do is get organic pads or soft compound aftermarket ones ( allthough i dont think anyone does them) you could possibly cut the hope trials pads down to fit your x2 caliper as they are a simmilar shape just wider and taller. so cut the sides and bottom down.
and use a larger rotor 183 or 203 will do.
as for bedding in water and light braking until a good sharp bite is spot on
