Carlperkins Posted February 1, 2012 Report Share Posted February 1, 2012 ok so i have an echo sl rear 24" 32h rim. (Weight : 565g. High : 23mm. Width : 38mm.) - info from the internet. and im going to buy an echo tr non disc rear hub. http://www.tartybikes.co.uk/135mm_fixed_hubs/echo_tr_rear/c21p10708.html (Flange Diameters: 40mm - Centre to Flanges: 35mm) can someone please tell me how to use the spoke calculator? i'm having difficulties much appreciated. carl. Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted February 1, 2012 Author Report Share Posted February 1, 2012 ok so i was trying to measure the rim diameter and i wasnt sure whether to measure from the outer edge of the rim to the other edge (the rims absolute widest point) or whether to measure from spoke hole to spoke hole. anyway i measured spoke hole to spoke hole and it came to 475mm (edge to edge is 521mm) spoke hole to spoke hole example.. then i punched it all into dt swiss and this is what came out... anyone think this is right? Quote Link to comment Share on other sites More sharing options...
JD™ Posted February 1, 2012 Report Share Posted February 1, 2012 (edited) According to this the ERD of the rears is 480mm, so you weren't far out EDIT: Any reason for 4cross? Wouldn't bother with more than 3 to be honest, just a little simpler. Edited February 1, 2012 by JD™ Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted February 1, 2012 Author Report Share Posted February 1, 2012 (edited) According to this the ERD of the rears is 480mm, so you weren't far out EDIT: Any reason for 4cross? Wouldn't bother with more than 3 to be honest, just a little simpler. ahh nice, i measures it with one of those flappy measuring tapes i found in my nans sewing box haha. ok so 480 and 3x.. ill put that in and see whats what.. edit. 236mm. sounds good yeah? i take it all the hub measurements i entered are correct? Edited February 1, 2012 by Carlperkins Quote Link to comment Share on other sites More sharing options...
