murph82 Posted February 1, 2012 Report Share Posted February 1, 2012 Might be a daft and obvious question but I'm finally finishing off my new 24 the next week or so as I'm well enough to ride again. The question is do cable discs still retain a nice feel if run through the steerer? With hydros it doesn't matter I know but I know the routing on cables effects the feel. I just can't be bothered to set it up then find out on my first ride in 6 months it's shite! Thanks Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted February 1, 2012 Report Share Posted February 1, 2012 It surely is a 5 minute job at most? I've never ran a cable on the front so can't comment, but if I wanted to find out, for the sake of a couple of minutes i'd certainly give it a go. I can't imagine it making it feel any worse. Quote Link to comment Share on other sites More sharing options...
aener Posted February 1, 2012 Report Share Posted February 1, 2012 I would've thought you'd be Ok. Just try and keep the curves as gentle as possible Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted February 1, 2012 Report Share Posted February 1, 2012 yeah i ran a bb5 through the headset. basically just make sure you have a decent cable, a £2 cable from halfords wont be very good. and make sure you have a nice amount of cable from the lever to the top cap, don't run it tight. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted February 1, 2012 Report Share Posted February 1, 2012 It works fine did it on mine Quote Link to comment Share on other sites More sharing options...
eskimo Posted February 1, 2012 Report Share Posted February 1, 2012 I'm using one and it's fine. Was also fine on the 24" when i used to run it. If the cable isn't a linear make the top curve relatively big. Quote Link to comment Share on other sites More sharing options...
murph82 Posted February 1, 2012 Author Report Share Posted February 1, 2012 thanks guys! Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted February 7, 2012 Report Share Posted February 7, 2012 How does running a V-brake in the same Way work? Does it affect the performance noticably? Quote Link to comment Share on other sites More sharing options...
Matthew_Gibson Posted February 7, 2012 Report Share Posted February 7, 2012 probably end up needing a long cable but I'd say it wont make the brake feel too good. just with the curve angle. if you know what I mean? Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted February 7, 2012 Report Share Posted February 7, 2012 I never tried it but i remember ali c saying they dont feel good. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted February 7, 2012 Report Share Posted February 7, 2012 Ok cheers lads. Quote Link to comment Share on other sites More sharing options...
T-Limburn Posted February 9, 2012 Report Share Posted February 9, 2012 Here is Euan's, works a treat! Quote Link to comment Share on other sites More sharing options...
murph82 Posted February 9, 2012 Author Report Share Posted February 9, 2012 Here is Euan's, works a treat! Nice one, cheers. What sort of length rear cable is he running to enable it to wrap round? Thanks Quote Link to comment Share on other sites More sharing options...
Revolver Posted February 9, 2012 Report Share Posted February 9, 2012 Buy a new cable, fit it on the frame and into the lever but not into the brake, then turn the bars around, and then decide how much you want to chop off. Quote Link to comment Share on other sites More sharing options...
