Doubt About Disc Brake
bagre15
I recently bought a hope tech trial for the rear. I've never used a rear disc before. Now I'm starting to get used with it. The brake has a small play, is it normal?
I've checked everything, and it's all tighthen up, but I still got the tiny play. Somebody can help me finding the cause of this? :turned:
should settle with time. what you will find is that the pad can slide a bit on the piston, after a bit of riding the piston will actually dent the back of the pad a little bit and that will stop most of the play. You could try removing the paint from the rear in effort to make the back of the pad have a bit more grip, but I don't think that will completely remove the play.
Thanks for the fast reply Ali, it's a bit strange to balance in the rear wheel with this litle play, but I'll get used to it :giggle:
BTW, rear disc brakes are awesome, they provide an awesome hold
