Bikes And Grease
Greetings
As the title says really. I'd love to get answers from professionals, not so much from people who have just been fiddling with their bikes for many years. I'm interested in the official answers.
Parts that interest me:
- Headset
- BB cups
- Crank-bb spline
- Crank bolts
- Pedal/crank threads
- Cog and freewheel threads
Thanks!
Pretty sure the official answer is yes to everything. Only debateable one is the headset to frame interface; some like it dry, others prefer a bit of grease.
I put copper anti sieze grease on freewheel and cog threads.
EDIT: Sorry, I'm not a professional (though have worked in a bike shop?)
Not a professional bike mechanic, nor have I worked in a bike shop, but I have been maintaining bikes and motorbikes for over twenty years now so I would say I have sufficient experience. IMHO time and experience is worth more than a piece of paper.
Personally the only place I wouldn't put grease is on a square taper BB/crank interface, I'm not sure if this is the 'professional' method but I've always assembled them dry and never had an issue :)
I've always greased square tapers as well and never had any issues... Any real reason why not to? I've always greased everything that's metal on metal on my bikes. I'm no 'pro' either but I've had very few issues and my kit lasts me a long long time.
ello. i have been fixing my own bikes for 20 years.
and been fixing bikes in idb shops for 8 years now. and took the cyctec level 2 and 3 nvq
and hers what you should be doing
- Headset : i use shimano anti seaze on the cups only if the metals are different. to avoid corrsion
- BB cups :again anti seaze i use all the time on bb cups there a nighmare to remove without it
- Crank-bb spline :anti seaze on any tipe except square taper. ( i have nver been told why thou) i asume the square taper could get damaged if there is any movement
- Crank bolts :anti seaze also for obvious reasons
- Pedal/crank threads : anti seaze copper slip is best for threads
- Cog and freewheel threads : anti seaze copper slip.
i do also find marine grase is very good on bikes as it silocon based and works on pretty much any surface including bearings.
white lighting do one for bikes now
  • Like 1
Nah, that's fine. Just wanted to avoid getting answers from 12-year olds who are currently owning their first trials bike (no offence intended towards said people). Seems to have worked.
Is copper grease a good all-rounder or should it be avoided in certain areas?
As for headsets, it sounds like alu ones can go into alu frames dry?
Thanks to all so far (Y)
Edited by Greetings
I grease everything other than headset cups, with square taper bbs I usually just rub it with an oily/greasy rag or put a dab of grease on then wipe it off.
copper stuff is great, best for threads, some sort of lithium grease is great for bearings and anti seize is great for threads or metal on metal contact points.
copper grease is great for all places that don't move. things you dont want to seize. so all other things such as the headset i use lithium grease
This (Y)
I'm going to hazard a guess as to why you don't generally grease up square taper. The joint relies on friction being formed in the taper, obviously any lubrication in there is going to tend to make it slip off a bit easier. Another aspect of it is that if it is lubricated on assembly, the lube will allow a greater torque to be applied when tightening the crank up, this could easily stretch the aluminium taper, especially if its a cheap set of cranks. Once its stretched you're permanently left with a baggy crank that wont tighten without resorting to shimming the tapers :)
"Like sleeve of wizard."
That's the idea, as said grease on a square taper bb allows over torquing of the crank bolt which can lead to the generally soft aluminium crank arm deforming causing it to come loose.
Copper slip on threads, grease on bearings and splined bbs and don't grease headset cups. Always use a threadlocking compound on disc rotor bolts.
only ever use lithium greace on bearings and nothing else,lithium grease is no good for anti seaze
i use silcon based marine greace i find it much better
it has better temperature handling
regular cyclists will benefit more using better waterproof silicon based grease which also will keep your rubber seals fresher and not cause them to dry up.
silicon grease
litium grease
if your going to buy some grease get some marine silicon greace and some copper slip
i use these white lightning crystal grease
and shimano anti seazei use this because its not as abrasive as copper slip, we use it because it doesnt damage bike seatposts annodizing when moving it up and down loads
Edited by dezmtber
interesting read so far, i like how hes asked for professinoal answers and still got the following.
just because you been doing some thing for 50 years doesnt make it the correct way.
pretty much every where needs to be greased or lubed in some way, arguments are generally about what types of grease is used for different materials.
why wouldnt you want to lube a tapper on a crank? the use of a torque wrench is to ensure the material isnt deformed
